mx6q usb otg as host
1,267 次查看
linhaiboyy
    I am working on mx6q, linux_core_3.0.35 .  I use mx6q as host, when I plug USB otg disk  in the mx6q, I chek up the OSB_OTG_ID is low power. And system printing below
when i pull out usb otg disk,system printing below
How can I solve this problem ?
标签 (1)
1 回复
1,179 次查看
had you modprobe necessary drivers as described in
documentation in ..mxc_usb_test/doc
http://repository.timesys.com/buildsources/i/imx-test/
