mx53 codec and hdmi audio
2,217 次查看
zhangenvi
Fresh Out Contributor
all,
    mx53 codec and hdmi audio can not work together. when open HDMI spdif , codec audio can't work.
why? thanks!
标记 (1)
3 回复数
2,075 次查看
fengwei
what program did you play the audio? aplay? paplay? Describe the command line should be helpful to check your issue.
2,075 次查看
zhangenvi
mx53 loco
Ray Sun said:
which board are you using? then we can check the reason.
2,075 次查看
Yanfei_Sun
