mx53 codec and hdmi audio
2,208件の閲覧回数
zhangenvi
all,
    mx53 codec and hdmi audio can not work together. when open HDMI spdif , codec audio can't work.
why? thanks!
タグ(1)
3 返答(返信)
2,066件の閲覧回数
fengwei
what program did you play the audio? aplay? paplay? Describe the command line should be helpful to check your issue.
2,066件の閲覧回数
zhangenvi
mx53 loco
Ray Sun said:
which board are you using? then we can check the reason.
2,066件の閲覧回数
Yanfei_Sun
