multi-touch limit on Sabre board?
2,682 次查看
_benjamindubb
Is there any particular reason why only two fingers are tracked by the touchscreen on Sabre i.MX6Q board? We see that with both Linux and Android images.
-Ben
标签 (4)
2,501 次查看
4guin4g4
There is no particular reason. The HW supports more than 2 touches, however the SW delivered only enables 2. You can  modify the driver to enable more than 2 touches.
2,502 次查看
4guin4g4
2,501 次查看
erichu
I have debug down to driver level, but only 2 id was received from i2c. and idea?
2,501 次查看
erichu
one more question, is there any place I can find the chip datasheet? I can not find anywhere on the internet.
