mount root partition - noatime,ro
joštnovak
I'm trying to mount root partition as read-only and with option noatime to avoid write cycles on SD card (on similar platform as sabresd).
setting bootargs this way:
bootargs_mmc=setenv bootargs ${bootargs} root=${cur_root_part} rootwait ro rootflags=noatime
gives me error: Unrecognized mount option "notime" or missing value
setting bootargs the way:
bootargs_mmc=setenv bootargs ${bootargs} root=${cur_root_part} rootwait ro,noatime
ignores the noatime option.
If any one can give me some thoughts on my problem, i would appreciate it very much!
Novak Jost
Labels (2)
OtavioSalvador
Senior Contributor II
This should be done, in the target filesystem, in the /etc/fstab file. You can pass the 'ro' option but not 'noatime' in the kernel command line.
By the way, please check the 'relatime' filesystem option as it may be more appropriate for your use/or not.
