Target:
i.mx6 Android 4.4.2 1.0.0~rc3
Kernel 3.0.35
Board: solid-run cubox-i som i1.
I uses i.mx6 with UVC camera and current configuration is like below.
V/CAM_VideoModule( 3280): mDesiredPreviewWidth=640. mDesiredPreviewHeight=480
I/FslCameraHAL( 2299): Width * Height 640 x 480 format 0x56595559, fps: 30
Now I wanna change resolution to below.
I/FslCameraHAL( 2299): SupportedPictureSizes: 1280 x 720
Android builder echos below process for default configuration.
target Prebuilt: media_profiles.xml (out/target/product/cuboxi/obj/ETC/media_profiles.xml_intermediates/media_profiles.xml)
Install: out/target/product/cuboxi/system/etc/media_profiles.xml
I want to change out/target/product/cuboxi/system/etc/media_profiles.xml
Where should I modify original media_profiles.xml?
:smileyhappy: , OK!
Weidong
When checking log data, below value is changed.
Initial value:
I/FslCameraHAL( 2299): mMaxWidth:1280, mMaxHeight:720
changed value;
I/FslCameraHAL( 2298): mMaxWidth:960, mMaxHeight:544
But below value are still not changed:
V/CAM_VideoModule( 3445): mDesiredPreviewWidth=640. mDesiredPreviewHeight=480
do you have any idea?
Dear Weidong,
One more thing, when I set below parameter manually, video broken.
width = 960; height =544; |
and while finding some information, it should be upgraded to KK4.4.3.
Do you have any idea?
I upload new UvcDevice.cpp and tested.
but resolution is still remains to 640*480 like attached.
Would you please check what should I do?
belowis new log.
V/CameraHolder( 3445): open camera 0
I/AwesomePlayer( 2298): setDataSource_l(URL suppressed)
I/Camera2ClientBase( 2298): Camerehci_fsl_bus_resume begins, DR
a 0: Opened
I/FslCameraHAL( 2298): camera_device open: 0
I/FslCameraHAL( 2298): DeviceAdapter: Create uvc device
ehci_fsl_bus_resume ends, DR
E/FslCameraHAL( 2298): Error: format 0x47504a4d not supported!
I/FslCameraHAL( 2298): pixel format: 0x56595559
I/FslCameraHAL( 2298): SupportedPictureSizes: 640 x 480
I/FslCameraHAL( 2298): SupportedPreviewSizes: 960 x 544
I/FslCameraHAL( 2298): SupportedPreviewSizes: 640 x 480
I/FslCameraHAL( 2298): FrameDuration is 33331760, 30000000000
E/FslCameraHAL( 2298): cpu num 1
W/Camera2-Parameters( 2298): buildFastInfo: Camera 0: activeArraySize is missing xmin/ymin!
I/Camera2-Parameters( 2298): Camera 0: Disabling ZSL mode
D/dalvikvm( 3445): GC_CONCURRENT freed 343K, 11% free 3527K/3936K, paused 2ms+1ms, total 19ms
V/NFC ( 3445): this device does not have NFC support
D/ ( 2661): AccelSensor enable 1 , handle 0 ,mEnabled 6
E/SensorService( 2661): Error activating sensor 0 (Operation not permitted)
V/CAM_VideoModule( 3445): startPreview
D/ ( 2661): AccelSensor enable 1 , handle 0 ,mEnabled 7
D/libEGL ( 3445): loaded /system/lib/egl/libEGL_VIVANTE.so
D/libEGL ( 3445): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
D/libEGL ( 3445): loaded /system/lib/egl/libGLESv2_VIVANTE.so
E/BufferQueue( 2295): [com.android.camera2/com.android.camera.VideoCamera] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
D/OpenGLRenderer( 3445): Enabling debug mode 0
V/CAM_VideoModule( 3445): Video snapshot size is 800x600
I/FslCameraHAL( 2298): DEBUG(CreateDefaultRequest): making template (1)
I/FslCameraHAL( 2298): DEBUG(CreateDefaultRequest): making template (3)
I/FslCameraHAL( 2298): RequestManager allocateStream...
I/FslCameraHAL( 2298): allocateStream preview stream, w:640, h:480, fmt:0x22
I/FslCameraHAL( 2298): actual format 0x103
I/FslCameraHAL( 2298): RequestManager allocateStream end...
I/FslCameraHAL( 2298): RequestManager registerStreamBuffers stream id:0
I/FslCameraHAL( 2298): registerBuffers total 5 buffer
I/FslCameraHAL( 2298): RequestManager registerStreamBuffers end...
I/FslCameraHAL( 2298): allocateStream jpeg stream, w:800, h:600, fmt:0x21
I/FslCameraHAL( 2298): RequestManager registerStreamBuffers stream id:3
I/FslCameraHAL( 2298): notify_request_queue_not_empty running
I/FslCameraHAL( 2298): dispatchRequest running
I/FslCameraHAL( 2298): handleRequest running
I/FslCameraHAL( 2298): PreviewStream configure running
I/FslCameraHAL( 2298): IS Width * Height 640 x 480 format 0x56595559, fps: 30
I/ActivityManager( 2661): Displayed com.android.camera2/com.android.camera.VideoCamera: +1s327ms
I/FslCameraHAL( 2298): PreviewStream start running
I/FslCameraHAL( 2298): StreamAdapter start running
I/FslCameraHAL( 2298): stream thread received STREAM_START command
I/FslCameraHAL( 2298): Created device thread
I've got source, thanks.
Thanks for your response, but i cant find attachment, would you please check again?
Sorry but I cant find link or attachment for UvcDeivice.cpp .
would you please let me know where should I download?
