menuconfig imx8m plus android 13
1,827 次查看
MJD
unable to run menu config
With the user guide i have set /etc/profile/
1,783 次查看
brian14
Hi @MJD,
Thank you for contacting NXP Support.
Can you point out the exact part that you are following from the Android User's Guide?
Android User's Guide (nxp.com)
Have a great day!
1,759 次查看
MJD
Hi @brian14
This is user guide followed.
AUG
Rev. android-13.0.0_2.0.0 — 31 July 2023
1,740 次查看
brian14
Hi @MJD,
Thank you for your reply.
It seems that the toolchain is not set correctly.
You can try removing the project and installing correctly the packages described in the same manual for the host.
Also, I couldn't find the part of "make menuconfig" in the manual. Could you explain the reason for building this? Usually, Android complete image is built using the command "lunch".
Have a great day!
