making remote debugger to work with Eclipse
1,246 次查看
kelvintan
I am new to iMX6d. Currently, I am trying to setup Eclipse on Ubuntu and would like to do remote debugging. As far as I know, openSSH server and gdb server are needed to install in the target device. However, I am struggling to find a working version of openSSH server and gdb server to the target device. Any help appreciated! Thanks.
标签 (2)
1,173 次查看
saurabh206
Senior Contributor III
Kelvin
You can use Yocto build for your i.MX6d.
You can select required package in your rootfs using yocto.
Saurabh
