I am using a cross compiler, to make a kernel for the i.mx6dl. If I set CONFIG_CC_OPTIMIZE_FOR_SIZE=y the compiler stops with an error. If I unset this option, the kernel will be compiled correcly.
| CC | drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.o |
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.c: In function 'gckKERNEL_Dispatch':
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.c:1160:9: error: 'node' may be used uninitialized in this function [-Werror=maybe-uninitialized]
cc1: all warnings being treated as errors
make[3]: *** [drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.o] Error 1
make[2]: *** [drivers/mxc/gpu-viv] Error 2
make[1]: *** [drivers/mxc] Error 2
make: *** [drivers] Error 2
Kernel: 3.0.35 from LTIB L3.0.35_4.1.0_130816
Compiler: gcc version 4.7.2 (Sourcery CodeBench Lite 2012.09-63)
Any Ideas how I can compile with this option?
Timo
Timo
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
Timo
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
Timo
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the issue, can we close the discussion? If you still need help, please feel free to reply with an update to this discussion.
Yixing
