make defconfig issue
2,252件の閲覧回数
wangtsungli
Hi Community,
I'm working on i.MX6 Quad sabre-SD platform and build Android 6 with android_M6.0.1_2.1.0_source.
Before I execute make, I get to folder kernel_imx to make my customize defconfig.
And it will generate a .config file under kernel_imx.
But When I try to make All project, .config would be changed to another defconfig.
Why would .config file be changed?
Is there any Makefile I need to mentioned?
ラベル(5)
2,126件の閲覧回数
wangtsungli
I had found the solution.
In device/fsl/imx6/soc/imx6dq.mk defined TARGET_KERNEL_DEFCONF.
I need to change it to my customize defconf.
I try to export my customize name and modify it to imx_$(MY_PRODUCT_NAME)_android_defconfig.
And it solve my problem!
2,127件の閲覧回数
wangtsungli
