ltib build error
ltib build error
996 次查看
danielabraham
Could some one help me to solve build error while building ltib for i.mx53 AI rev B board.The error is, these packages failed to build: evolution-data serer. I tried to install package using apt-get install, but the same error is shown. I'm using a ubuntu 9.04 version for building ltib.
834 次查看
gusarambula
I’m sorry to hear you’re having issues building the image.
Which package did you tried to install? Was it the following?
$ sudo aptitude install evolution-data-server-dev
It so, did it installed correctly or was the package no longer available? Did you added the old-releases repositories as directed on section 1.2 of the Setting Up LTIB Host document? It is possible that a repository is no longer available.
