Hi all
I have custom board with nand chip of Micron MT29F4G08ABBDAH4
when in 3.0.35-4.0.0 version , this can boot ,both kernel and kobs-ng is based on 3.0.35-4.0.0 version
But when I try to update to 3.10.17-ga kernel and kobs-ng from http://www.freescale.com/lgfiles/NMG/MAD/YOCTO/imx-kobs-3.10.17-1.0.0.tar.gz
u-boot failed when boot from power on,no problem from usb .
And I also test 3.10.17-ga kernel and new kobs-ng on another ONFI 2.0 nand board, It boot sucessful
Can you test on about this ?
Kernel version of 3.10.17-ga and ONFI 1.0 spec SLC nand
Thanks and regards
Xiongwei
Original Attachment has been moved to: kobs.txt.zip
已解决! 转到解答。
Hi all
Update information , its' my mistake of config DCD,
I following the sabrelite board DCD config , as default , sabrelite turn off the gpmi clock for power saving
But when boot from usb, seems bootrom skip the DCD clcok config .
And when boot from nand , the DCD table take effects
its a little odd.
Thanks and regards
Hi all
its a little odd.
Thanks and regards
Hello Alejandro
No serial output ,when from nand boot .
And from usb boot , u-boot nand dump look like this
nand dump 0
Page 00000000 dump:
00 00 00 00 00 00 00 00 00 00 00 00 c6 fb ff ff
46 43 42 20 00 00 00 01 50 3c 19 06 00 00 00 00
00 08 00 00 40 08 00 00 40 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 04 00 00 00 00 02 00 00
00 02 00 00 04 00 00 00 0a 00 00 00 03 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 02 00 00 00 04 00 00 8a 00 00 00
8a 00 00 00 00 01 00 00 cf 07 00 00 00 00 00 00
nand dump 100000
Page 00100000 dump:
00 ff ff ff ff ff ff ff ff ff 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 c4 9c 35 4a b8 af
b0 dc 2b 99 d1 14 44 00 00 00 00 00 00 00 00 00
00 00 00 00 d1 00 20 40 00 00 80 17 00 00 00 00
2c b0 7f 17 20 b0 7f 17 00 b0 7f 17 00 00 00 00
00 00 00 00 00 ac 7f 17 00 4e 04 00 00 00 00 00
d2 03 40 40 cc 03 3c 04 02 0e 05 a8 00 00 00 30
02 0e 05 b0 00 00 00 30 02 0e 05 24 00 00 00 30
02 0e 05 1c 00 00 00 30 02 0e 05 18 00 00 00 30
02 0e 05 0c 00 00 00 30 02 0e 05 b8 00 00 00 30
Seems 1M offset u-boot.imx is ok ?
