kea server for dhcp server
2,201 次查看
mjaafar
 I am working on wifi and trying to configure a hotspot using : hotspotd and kea server (dhcp server in no more in yocto distrib).
I have a problem when a device connects there is no ip address attribution done and kea does not give a lease eto the device.
Can you please help me with kea configuration with hotspotd.
Thank you
3 回复数
2,175 次查看
Manuel_Salas
Hello @mjaafar ,
Could you please share more details?
Are you using an i.MX?
What WIFI are you using?
What BSP?
Best regards!
2,167 次查看
mjaafar
I am using IMx8mplus board
Laird wifi
yocto.
2,150 次查看
Manuel_Salas
Hello @mjaafar ,
I believe you should go with Laird, In general wifi porting guidelines should be provided by wifi vendor.
Apologies for inconvenient.
Our BSPs (Example 5.4.70) supports WIFI 88w8997 and 88w8987.
Best regards!
