- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Dear all,
I searched the forum and found this question was asked earlier but no clear answer mentioned. Could someone from freescale tell how to decode jpeg using vpudec commandline or C code. I am it will be extremely useful for me and many more.
https://community.freescale.com/thread/304879
gst-launch filesrc location=./jeep.jpg ! vpudec ! imagefreeze ! mfw_isink axis
-top=540 axis-left=960 disp-width=960 disp-height=540
MFW_GST_ISINK_PLUGIN 3.0.5 build on Apr 17 2013 12:11:46.
Setting pipeline to PAUSED ...
[INFO] Product Info: i.MX6Q/D/S
vpudec versions
plugin: 3.0.5
wrapper: 1.0.28(VPUWRAPPER_ARM_LINUX Build on Apr 17 2013 12:09:59)
vpulib: 5.4.10
firmware: 2.1.8.34588
Pipeline is PREROLLING ...
** (gst-launch-0.10:1255): CRITICAL **: gst_vpudec_chain: assertion `vpudec->context.handle' failed
When I tried same with jpgdec, CPU went upto 100% on one core. It does display image.
解決済! 解決策の投稿を見る。
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Alok,
This pipeline works on my side and it is not using imagefreeze, the only problem is that display lasts for some milliseconds :smileyhappy:
VSALPHA=1 gst-launch filesrc location=sample.jpeg ! jpegdec ! mfw_isink
Leo
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Alok,
There is some sample code I have done before for alsa sound , you could refer some part, by the way after use the gstreamer cmd , then use top command, after the picture displayed, the CPU load is very small, so I don't know how you test this, how and when?
GstBus *bus; | |
GstElement *pipeline; |
GstElement *alsasrc,*appsink; | |
GstCaps *caps; | |
buffer_in = (char*) malloc( BUF_SIZE1); | |
buffer_out = (char*) malloc( BUF_SIZE2); |
loop = g_main_loop_new(NULL,FALSE); |
gst_init(NULL,NULL); |
pipeline = gst_pipeline_new("test"); |
alsasrc = gst_element_factory_make("alsasrc","alsasrc"); | |
appsink = gst_element_factory_make("appsink","appsink"); |
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline)); | |
gst_bus_add_watch (bus, bus_call, loop); |
gst_object_unref (bus);
// | g_object_set(G_OBJECT(alsasrc),"device","hw:0,0,0",NULL); |
caps = gst_caps_new_simple("audio/x-raw-int", | ||||
"endianness",G_TYPE_INT,1234, | ||||
"signed",G_TYPE_BOOLEAN,TRUE, | ||||
"width",G_TYPE_INT,16, | ||||
"depth",G_TYPE_INT,16, | ||||
"rate",G_TYPE_INT,44100, | ||||
"channels",G_TYPE_INT,2, | ||||
NULL); | ||||
gst_app_sink_set_caps((GstAppSink *)appsink,caps); |
g_object_set(G_OBJECT(appsink),"emit-signals",TRUE,NULL); | |
g_signal_connect(appsink,"new-buffer",G_CALLBACK(on_new_buffer_from_source),NULL); |
gst_bin_add_many(GST_BIN(pipeline),alsasrc,appsink,NULL); |
gst_element_link_many(alsasrc,appsink,NULL); | |
asrc_fd = asrc_init_config(); | |
src = create_appsrc_pipeline(); | |
gst_element_set_state(pipeline,GST_STATE_PLAYING); | |
g_main_loop_run(loop); |
gst_element_set_state(pipeline,GST_STATE_NULL); |
gst_object_unref(GST_OBJECT(pipeline)); |
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Thanks Junping for sharing the code.
I am not sure if this code is any different than what I put earlier.
Actually so far I have been unsuccessful in using jpegdec without imagefreeze for jpeg display even using gst-launch.
any inputs will be helpful.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Alok,
Leo
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
it seems vpudec just can support mjpeg video, if one picture, need to use jpegdec.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
With some reason I have been getting three issues with jpegdec
1. CPU utilization is very high, with 2 jpeg display it goes up to 100% on one core.
2. most of the jpeg files end up in source format error . Any suggestions how to play all jpeg files.
3. When I playing a picture I took from nokia lumia 920, it was split on the display. I was surprise to see that.
Any helping pointers are highly appreciated.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Alok.
Regarding 1, do you see the same behavior using gst-launch? It would be interesting to check which gst element is causing this high CPU usage, it may be the freeze element.
Regarding 2, It could be that those non-working jpegs have non-standard headers. Could you please post one of this to see the error/header?
Regarding 3, yes, This is a known issue. We are working on this.
Leo
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Leo,
1. I noticed that with gst-launch cpu load was almost 50% compare to C code(above). I was not sure why.
This was the original pipeline and after removing "imagefreeze" pipeline fails
I would be very interested to know if there is a way to do it without imagefreeze.
2. I am attaching jpeg file, which I could not play without aligning to 8 pixel boundary.
Thanks a lot
-Alok
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
the CPU usage should be high during a short period, because it's decode by software
didn't see that, could you check the your code according to the guide in this community
How large size is this picture?
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Thanks Junping Mao.
1. cpu utilization remains high through out.
Please see the code and suggest if something is incorrect.
GstBin *Bin;
GstBus *bus;
GMainLoop *Mainloop;
gst_init (&argc,&argv);
Mainloop = g_main_loop_new(NULL,FALSE);//NULL to use the current context and False to tell its not in running state
GstElement *pipeline = gst_pipeline_new("PIPELINE");
Bin = GST_BIN(pipeline);
bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
source = gst_element_factory_make("filesrc","file-source");
g_object_set(G_OBJECT(source),"location",argv[1],NULL);
imagedecoder = gst_element_factory_make("jpegdec","decoder");
imagefreeze = gst_element_factory_make("imagefreeze","imagefreeze");//"Vorbis audio decoder","vorbis");
video_sink = gst_element_factory_make("mfw_isink","XV video sink ");
int axis_top=0;
int axis_left=0;
int disp_width=1920;
int disp_height=1080;
g_object_set(G_OBJECT(video_sink),"axis-top",axis_top,"axis-left",axis_left,"disp-width",disp_width,"disp-height",disp_height,NULL);
gst_bin_add(Bin,source);
gst_bin_add_many(Bin,imagedecoder,imagefreeze,video_sink,NULL);
gst_element_link(source,imagedecoder);
gst_element_link(imagedecoder,imagefreeze);
gst_element_link(imagefreeze,video_sink);
gst_bus_add_watch(bus,process_message,Mainloop); //Mainloop is passed as user data as in the process_message actions are taken on the loop
g_object_unref(bus);
g_print("In playing state\n");
gst_element_set_state(pipeline,GST_STATE_PLAYING);//Pipeline is also a bin and bin is also an element at abstract level and hence gst_element_set_state call is used to set state of pipeline.
g_main_loop_run(Mainloop);
g_print("In playing state2\n");
g_object_unref(G_OBJECT(pipeline));
2. This problem was solved after making sure files are 8*8 pixel format.
3. I thing there is some issue with playing files bigger than 1080P.
Alok
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
No, the vpudec doesn't support jpeg decode, you should use open source jpeg plugin, also in community has article to introduce how to enable the jpeg decode
