issue about imx6 uart dma
11,329 次查看
宗標廖
Hello Community
My customer uses BSP3.0.35_4.1.0 on i.mx6dl and they connected BT to UART4, and they enabled SDMA for UART4.
They found that when the BT chip is communicating with i.MX6, sometimes the Rx DMA of UART4 goes to stop.
Could you give me some advice to resolve this problem?
Best Regards
ZongbiaoLiao
标签 (2)
5 回复数
10,291 次查看
Hi ZongbiaoLiao
please check attached Linux Manual Chapter 39
Universal Asynchronous Receiver/Transmitter (UART) Driver
If you want to use the DMA support for UART please also
enable the RTS/CTS for it. The DMA may be abnormal if you
do not enable the RTS/CTS.
10,291 次查看
宗標廖
Hi igor
Thank you for you reply.
My customer used CTS/RTS. So is there any other possible reason?
Best Regards
ZongbiaoLiao
10,289 次查看
Hi ZongbiaoLiao
since L3.0.35 uart driver was significantly changed, for example
refer to attached patches. So recommendation to migrate to more new kernels.
10,289 次查看
宗標廖
Hi igor
Thank you for offer me patches.
My customer's project is based on L3.0.35_4.1.0, now it is impossible(no time) to migrate to newer BSP.
Best Regards
ZongbiaoLiao
10,289 次查看
Hi ZongbiaoLiao
L3.0.35_4.1.0 is old bsp and not supported in usual way,
it is removed from nxp bsps software page
i.MX 6 / i.MX 7 Series Software and Development Tool|NXP
 its support provided by NXP Professional Services:
http://www.nxp.com/support/nxp-professional-services:PROFESSIONAL-SERVICE
