inetd: command not found!
3,590 次查看
fabio_poiatti
Hi builded a core-image-base for imx6ullevk from the last sumo release ...
How con include the inetd functions?
Fabio
6 回复数
3,502 次查看
b36401
Our BSP supposes that all network services are running standalone, not with inetd.
You can try to install inetd package. However we have no experience with it. Sorry for the inconvenience.
3,502 次查看
fabio_poiatti
how can install inetd?
3,502 次查看
b36401
Here I found inetd for busybox:
https://patchwork.openembedded.org/patch/137270/
3,502 次查看
fabio_poiatti
thanks
3,502 次查看
b36401
You may add a layer to an image by adding IMAGE_INSTALL_append option to the conf/local.conf file inside the build directory, and then baking the image.
3,502 次查看
fabio_poiatti
what IMAGE_INSTAL I have to append?
I've already ..
IMAGE_INSTALL_append=" imx-test"
IMAGE_INSTALL_append+=" openssh"
IMAGE_INSTALL_append+=" tcf-agent"
IMAGE_INSTALL_append+=" openssh-sftp-server"
IMAGE_INSTALL_append+=" ppp"
