incorrect cfg-File for imx8mn_ddr4_evk?
1,117件の閲覧回数
klaus_dannecker
the Evalboard imx8mn_ddr4_evk has ddr4 ram (no lpddr4)
in the imx8mn_ddr4_evk_defconfig is referred to arch/arm/mach-imx/imx8m/imximage.cfg File
in this File is config plddr4 and not ddr4
DDR_FW lpddr4_pmu_train_1d_imem.bin
DDR_FW lpddr4_pmu_train_1d_dmem.bin
DDR_FW lpddr4_pmu_train_2d_imem.bin
DDR_FW lpddr4_pmu_train_2d_dmem.bin
is that correct?
or should another file be used, like imximage_ddr4.cfg?
that used
DDR_FW ddr4_imem_1d.bin
DDR_FW ddr4_dmem_1d.bin
DDR_FW ddr4_imem_2d.bin
DDR_FW ddr4_dmem_2d.bin
Sourcecode : https://source.codeaurora.org/external/imx/uboot-imx branch imx_v2019.04_4.19.35_1.1.0
Klaus
1,021件の閲覧回数
AldoG
Please note that the i.MX 8MN is still not supported in that release, for i.MX 8MN please use L4.14.98_2.3.0.
From L4.19.35_1.1.0
Thank you,
Aldo.
