imx95 low power mode
4,439件の閲覧回数
kannappan
I am working on a custom i.MX95 board running Linux 6.12 (Yocto-based). I am facing a suspend-to-RAM (deep sleep) failure related to the USB3 host controller. When executing echo mem > /sys/power/state, the system aborts suspend with xhci-hcd: WARN: xHC CMD_RUN timeout followed by PM: failed to suspend async: error -110. The issue occurs consistently when USB host mode is enabled, even with no active USB traffic. I am using a fixed 5V VBUS regulator controlled by a GPIO, and the USB3 controller, PHY, clocks, and power-domains are defined in the DTS (attached). My requirement is to fully power off USB VBUS during low power mode while allowing the system to enter deep sleep successfully. I have attached the full suspend/resume dmesg logs and the relevant USB-related DTS nodes for reference. I would like guidance on the correct DTS and/or driver-side handling required to avoid the xHCI suspend timeout on i.MX95.
3,955件の閲覧回数
Rita_Wang
Hi @kannappan ,
OK, we are going to have the New Year's Day holiday. when I back to office I will try it on our board and then give your reply.
Wish you have a nice day
Best Regards
Rita
5 返答(返信)
4,269件の閲覧回数
Rita_Wang
Could you share us the details steps, that we can reporcuce it on our EVK Board? Thanks
4,260件の閲覧回数
kannappan
In custom board iam using fusb302 but not enabled as usb3.0 , we are using it as usb2.0 .
but when entering into deep sleep ( echo mem > /sys/power/state ) The error is occuring in xhci-hcd driver.
Test Setup:
• SoC: i.MX95
• OS: Yocto Linux (kernel 6.x, NXP BSP)
• USB Mode: Host (xHCI, USB3)
• Connected Device: USB flash drive (Mass Storage)
  • Boot the board normally.
  • Connect a USB storage device to the USB3 host port.
  • Verify enumeration using lsusb and confirm device is accessible.
  • Enter low power mode using:
    After this step itself it is showing error.
  • Resume the system using the configured wake-up source (power button/ GPIO).
  • After resume, observe that the USB device either:
    • is not detected, or
    • shows xHCI / DWC3 related errors in dmesg, or
    • requires USB re-plug to work again.
ERROR LOGS :
[ 117.057281] PM: suspend entry (deep)
[ 117.066009] Filesystems sync: 0.005 seconds
[ 117.071209] Freezing user space processes
[ 117.076800] Freezing user space processes completed (elapsed 0.001 seconds)
[ 117.083781] OOM killer disabled.
[ 117.087011] Freezing remaining freezable tasks
[ 117.132725] Freezing remaining freezable tasks completed (elapsed 0.041 seconds)
[ 117.140164] printk: Suspending console(s) (use no_console_suspend to debug)
[ 117.156868] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 117.267552] xhci-hcd xhci-hcd.2.auto: WARN: xHC CMD_RUN timeout
[ 117.267611] xhci-hcd xhci-hcd.2.auto: PM: dpm_run_callback(): platform_pm_suspend returns -110
[ 117.267631] xhci-hcd xhci-hcd.2.auto: PM: failed to suspend async: error -110
[ 117.267702] PM: Some devices failed to suspend, or early wake event detected
[ 117.268017] hub 1-0:1.0: hub_ext_port_status failed (err = -108)
[ 117.268044] usb usb1-port1: cannot disable (err = -108)
[ 117.516365] PM: resume devices took 0.248 seconds
[ 117.570639] OOM killer enabled.
[ 117.573777] Restarting tasks ... done.
[ 117.575261] sd 0:0:0:0: [sda] Test Unit Ready failed: Result: hostbyte=0x01 driverbyte=DRIVER_OK
[ 117.578423] random: crng reseeded on system resumption
[ 117.587117] sda: detected capacity change from 120164352 to 0
[ 117.598136] PM: suspend exit
-sh: echo: write error: Connection timed out
3,956件の閲覧回数
Rita_Wang
Hi @kannappan ,
Best Regards
Rita
3,485件の閲覧回数
kannappan
HI @Rita_Wang ,
Is there any reply for the above issue.
Best Regards
Kannappan
3,467件の閲覧回数
Rita_Wang
Hi @kannappan ,
Sorry for too busy this week, I will test it for you next week and share the result to you.
Best Regards
Rita
%3CLINGO-SUB%20id%3D%22lingo-sub-2269225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx95%20%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBLOCKQUOTE%3E%3CP%3E%E7%A7%81%E3%81%AF%20Linux%206.12%20(Yocto%20%E3%83%99%E3%83%BC%E3%82%B9)%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20i.MX95%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82USB3%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%20RAM%20%E3%81%B8%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%20(%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97)%20%E9%9A%9C%E5%AE%B3%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82echo%20mem%20%26gt%3B%20%2Fsys%2Fpower%2Fstate%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%20xhci-hcd%3A%20WARN%3A%20xHC%20CMD_RUN%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%80%81%E7%B6%9A%E3%81%84%E3%81%A6%20PM%3A%20%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20-110%20%E3%81%A7%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E3%82%92%E4%B8%AD%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82USB%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%20USB%20%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%20GPIO%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%82%8B%E5%9B%BA%E5%AE%9A%205V%20VBUS%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81USB3%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%80%81PHY%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E9%9B%BB%E6%BA%90%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%81%AF%20DTS%20(%E6%B7%BB%E4%BB%98)%20%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AF%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%E4%B8%AD%E3%81%AB%20USB%20VBUS%20%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%2F%E5%86%8D%E9%96%8B%20dmesg%20%E3%83%AD%E3%82%B0%E3%81%A8%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%20USB%20%E9%96%A2%E9%80%A3%E3%81%AE%20DTS%20%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82i.MX95%20%E3%81%A7%20xHCI%20%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%AD%A3%E3%81%97%E3%81%84%20DTS%20%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%81%B4%E3%81%AE%E5%87%A6%E7%90%86%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%82%92%E5%B8%8C%E6%9C%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx95%20low%20power%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECAN%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E6%89%8B%E9%A0%86%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx95%20low%20power%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%20fusb302%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81usb3.0%20%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81usb2.0%20%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%A8%20(%20echo%20mem%20%26gt%3B%20%2Fsys%2Fpower%2Fstate%20)%E3%80%81xhci-hcd%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E2%80%A2%20SoC%3A%20i.MX95%3CBR%20%2F%3E%E2%80%A2%20OS%3A%20Yocto%20Linux%20(%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%206.x%E3%80%81NXP%20BSP)%3CBR%20%2F%3E%E2%80%A2%20USB%E3%83%A2%E3%83%BC%E3%83%89%3A%20%E3%83%9B%E3%82%B9%E3%83%88%20(xHCI%E3%80%81USB3)%3CBR%20%2F%3E%E2%80%A2%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%20USB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%EF%BC%88%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E9%80%9A%E5%B8%B8%E9%80%9A%E3%82%8A%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EUSB%20%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%20USB3%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3Elsusb%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%88%97%E6%8C%99%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%AC%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A8%E3%82%B3%E3%83%BC%E3%83%A1%E3%83%A2%E3%83%AA%20%26gt%3B%20%2Fsys%2Fpower%2Fstate%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E8%87%AA%E4%BD%93%E3%81%AE%E5%BE%8C%E3%81%AB%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%20%E3%82%BD%E3%83%BC%E3%82%B9%20(%E9%9B%BB%E6%BA%90%E3%83%9C%E3%82%BF%E3%83%B3%2F%20GPIO)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%86%8D%E9%96%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%86%8D%E9%96%8B%E5%BE%8C%E3%80%81USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E6%AC%A1%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3Edmesg%E3%81%ABxHCI%20%2F%20DWC3%E9%96%A2%E9%80%A3%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%86%8D%E3%81%B3%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%20USB%20%E3%82%92%E5%86%8D%E5%BA%A6%E5%B7%AE%E3%81%97%E8%BE%BC%E3%82%80%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A8%E3%82%B3%E3%83%BC%E3%83%A1%E3%83%A2%E3%83%AA%20%26gt%3B%20%2Fsys%2Fpower%2Fstate%3CBR%20%2F%3E%20%5B%20117.057281%5D%20PM%3A%20%E9%80%B2%E5%85%A5%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%EF%BC%88%E6%B7%B1%E9%83%A8%EF%BC%89%3CBR%20%2F%3E%20%5B%20117.066009%5D%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E5%90%8C%E6%9C%9F%3A%200.005%E7%A7%92%3CBR%20%2F%3E%5B%20117.071209%5D%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E7%A9%BA%E9%96%93%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%3CBR%20%2F%3E%5B%20117.076800%5D%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E7%A9%BA%E9%96%93%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AE%E5%87%8D%E7%B5%90%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E7%B5%8C%E9%81%8E%E6%99%82%E9%96%93%200.001%E7%A7%92%EF%BC%89%3CBR%20%2F%3E%20%5B%20117.083781%5D%20OOM%E3%82%AD%E3%83%A9%E3%83%BC%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20117.087011%5D%20%E6%AE%8B%E3%82%8A%E3%81%AE%E5%87%8D%E7%B5%90%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E5%87%8D%E7%B5%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%20117.132725%5D%20%E6%AE%8B%E3%82%8A%E3%81%AE%E5%87%8D%E7%B5%90%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%87%8D%E7%B5%90%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E7%B5%8C%E9%81%8E%E6%99%82%E9%96%93%200.041%20%E7%A7%92%EF%BC%89%3CBR%20%2F%3E%5B%20117.140164%5D%20printk%3A%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%20no_console_suspend%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3CBR%20%2F%3E%5B%20117.156868%5D%20sd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20SCSI%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E5%90%8C%E6%9C%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%20117.267552%5D%20xhci-hcd%20xhci-hcd.2.auto%3A%20%E8%AD%A6%E5%91%8A%3A%20xHC%20CMD_RUN%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3CBR%20%2F%3E%5B%20117.267611%5D%20xhci-hcd%20xhci-hcd.2.auto%3A%20PM%3A%20dpm_run_callback()%3A%20platform_pm_suspend%20%E3%81%AF%20-110%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%20117.267631%5D%20xhci-hcd%20xhci-hcd.2.auto%3A%20PM%3A%20%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20-110%3CBR%20%2F%3E%5B%20117.267702%5D%20PM%3A%20%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E3%81%8B%E3%80%81%E6%97%A9%E6%9C%9F%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%20117.268017%5D%20%E3%83%8F%E3%83%96%201-0%3A1.0%3Ahub_ext_port_status%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(err%20%3D%20-108)%3CBR%20%2F%3E%20%5B%20117.268044%5D%20usb%20usb1-port1%3A%20%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(err%20%3D%20-108)%3CBR%20%2F%3E%20%5B%20117.516365%5D%20PM%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%86%8D%E9%96%8B%E3%81%AB0.248%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%20117.570639%5D%20OOM%E3%82%AD%E3%83%A9%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20117.573777%5D%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20117.575261%5D%20sd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20%E3%83%86%E3%82%B9%E3%83%88%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E6%BA%96%E5%82%99%E5%A4%B1%E6%95%97%3A%20%E7%B5%90%E6%9E%9C%3A%20%E3%83%9B%E3%82%B9%E3%83%88%E3%83%90%E3%82%A4%E3%83%88%3D0x01%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%82%A4%E3%83%88%3DDRIVER_OK%3CBR%20%2F%3E%20%5B%20117.578423%5D%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%3A%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%86%8D%E9%96%8B%E6%99%82%E3%81%ABcrng%E3%81%8C%E5%86%8D%E3%82%B7%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%20117.587117%5D%20sda%3A%20%E5%AE%B9%E9%87%8F%E3%81%8C%20120164352%20%E3%81%8B%E3%82%89%200%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%20117.598136%5D%20PM%3A%20%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E7%B5%82%E4%BA%86%3CBR%20%2F%3E-sh%3A%20echo%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%8E%A5%E7%B6%9A%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx95%20low%20power%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257117%22%20target%3D%22_blank%22%3E%40kannappan%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%95%E3%81%A6%E3%80%81%E5%85%83%E6%97%A6%E3%81%AF%E4%BC%91%E3%81%BF%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%AA%E3%83%95%E3%82%A3%E3%82%B9%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%9F%E3%82%89%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E3%81%94%E8%BF%94%E7%AD%94%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2290750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx95%20low%20power%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2290750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%20%E3%80%81%3CBR%20%2F%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E8%BF%94%E7%AD%94%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%E3%83%8A%E3%83%91%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2290911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx95%20low%20power%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2290911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257117%22%20target%3D%22_blank%22%3E%40kannappan%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%BB%8A%E9%80%B1%E3%81%AF%E5%BF%99%E3%81%97%E3%81%99%E3%81%8E%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%9D%A5%E9%80%B1%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E7%B5%90%E6%9E%9C%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E
