imx93 evk peripherals testing
Et_MM
I am working with imx93 EVk. Recently i have tested the following pheripherals:
GPIO,ETHERNET,WIFI,BLUETOOTH,I2C EXPANSION,ADC,CAMERA. In the quick start guide i can see some more pheripherals like:
MIPI DSI,PDM MIC,GPIO EXP,RDPM I/F,CAN,USB2.0 C x2,Audio Jack,M.2 slot (E-KEY).
Can you please help me through the commands or procedure to test these peripherals in the I.MX93 EVK board.
Zhiming_Liu
Please refer https://www.nxp.com/docs/en/user-guide/UG10163.pdf and https://www.nxp.com/docs/en/reference-manual/RM00293.pdf
There are some test code in /unit_tests, the source code is here:
https://github.com/nxp-imx/imx-test/tree/lf-6.12.34_2.1.0/test
Zhiming
Et_MM
Thank you for the reply. I will check this.
Could you please help me with MQS peripheral in imx93 evk(J1301). what is this peripheral? what is the requirement of this in this imx93 evk board?
%3CLINGO-SUB%20id%3D%22lingo-sub-2266551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx93%20evk%20peripherals%20testing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20working%20with%20%3CSTRONG%3Eimx93%20EVk%3C%2FSTRONG%3E.%20Recently%20i%20have%20tested%20the%20following%20pheripherals%3A%3CBR%20%2F%3E%3CSTRONG%3EGPIO%2CETHERNET%2CWIFI%2CBLUETOOTH%2CI2C%20EXPANSION%2CADC%2CCAMERA.%20%3C%2FSTRONG%3EIn%20the%20quick%20start%20guide%20i%20can%20see%20some%20more%20pheripherals%20like%3A%26nbsp%3B%3CBR%20%2F%3E%3CSTRONG%3EMIPI%20DSI%2CPDM%20MIC%2CGPIO%20EXP%2CRDPM%20I%2FF%2CCAN%2CUSB2.0%20C%20x2%2CAudio%20Jack%2CM.2%20slot%20(E-KEY).%3CBR%20%2F%3E%3C%2FSTRONG%3ECan%20you%20please%20help%20me%20through%20the%20commands%20or%20procedure%20to%20test%20these%20peripherals%20in%20the%20%3CSTRONG%3EI.MX93%20EVK%20board.%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx93%20evk%20peripherals%20testing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHow%20can%20I%20test%20CAN%20in%20imx93%20evk%20board%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx93%20evk%20peripherals%20testing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3E%3CBR%20%2F%3EPlease%20refer%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUG10163.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUG10163.pdf%3C%2FA%3E%26nbsp%3Band%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Freference-manual%2FRM00293.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Freference-manual%2FRM00293.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThere%20are%20some%20test%20code%20in%20%2Funit_tests%2C%20the%20source%20code%20is%20here%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-test%2Ftree%2Flf-6.12.34_2.1.0%2Ftest%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-test%2Ftree%2Flf-6.12.34_2.1.0%2Ftest%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx93%20evk%20peripherals%20testing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20the%20reply.%20I%20will%20check%20this.%3C%2FP%3E%3CP%3ECould%20you%20please%20help%20me%20with%20%3CSTRONG%3EMQS%3C%2FSTRONG%3E%20peripheral%20in%20imx93%20evk(%3CSTRONG%3EJ1301%3C%2FSTRONG%3E).%20what%20is%20this%20peripheral%3F%20what%20is%20the%20requirement%20of%20this%20in%20this%20imx93%20evk%20board%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
