imx8ulp misc gpio
imx8ulp misc gpio
1,278 次查看
tangchao90
I now want to design a program to determine whether a pull-up resistor exists!
below pins: onoff, tamper0, tamper1, reset and so on
but i do not how to control these
1,266 次查看
Zhiming_Liu
If my understanding is correct, you want to use program to operate misc gpios(output/input/set high/set low) to check whether a pull-up resistor exists. Is that correct?
Zhiming
1,249 次查看
tangchao90
yes!
1,234 次查看
Zhiming_Liu
The ONOFF, tamper0, tamper1, reset is not standard GPIO, these io has special function which could affect system running. We don't recommend you use these IO in your program.
Zhiming
