imx8plus dsp
924件の閲覧回数
wtking
Hello, nxp developers
Can anyone confirm that hifi4 dap can be used as common dsp? I want use it for sensor data calculation.
By the way, can uart be sxtended?We need 5 uart, but 8mplus datasheet say there are only 4.
thanks!
880件の閲覧回数
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
DSPs are used through their firmware, please refer to https://www.nxp.com/docs/en/user-guide/IMX_DSP_USERS_GUIDE.pdf.
I found the chapter about NatureDSP Library Support, is the library that matches the common operations of a DSP.
Used signal processing functions: FFT, FIR, vector, matrix, and common mathematics.
For UART expansion, you could either look for multiplexer/bridges or simulate a UART from GPIO, that development would be up to you.
881件の閲覧回数
JosephAtNXP
874件の閲覧回数
wtking
Thank you very much for your reply. We will take a detailed look at the PDF.Sincere thanks.
