imx8mqevk, hardware acclerators for object detection
1,513 次查看
manizillion
Hi ,
We are using v4l2 mipi camera on imx8mqevk, its very slow to respond on the display. Since
there are no g2d support for imx8mqevk to make it fast responsive,should we move to g3d APIs?
can you please confirm on this ? refer below for this.
https://community.nxp.com/message/1254512
If there is no g2d support then it should be g3d accelerators support, Can you please share a sample code for LIVE camera based object detection which would run on GC7000 gpu of imx8mqevk.
3 回复数
1,421 次查看
Bio_TICFSL
Hello Manivannan,
In the User guide document in your yocto documentation there is a chapter commented about the multimedia cases you may have, please check it.
1,421 次查看
manizillion
Hi ,
Can you please share the reference link to the document , i am not sure which document to look for GPU level programming on live camera object detection.
1,421 次查看
manizillion
The application is very slow on imx8mqevk gpu, the latest apps released are last month.
Mani
