imx8mq: yuv format support on eLCDIF
2,044 次查看
jignesh1
Dear NXP Team,
We want to display YUV format video decoded by VPU on eLCDIF. We checked with latest release 4.14 release and came to know that eLCDIF driver only support RGB data format.
Is there any driver available to support YUV data format on eLCDIF.?
Please let me know if there are any limitations to support this format.
Jignesh Patel
标签 (2)
5 回复数
1,912 次查看
Bio_TICFSL
Hi Jignesh,
The i.MX8MQ does not provide the driver, but the GPU can process the YUV source data and output it to RGB format, in this case, the output RGB data can be sent to eLCDIF channel.
1,912 次查看
jignesh1
Thank you,
So do you have any sample example by which we can test it. ?
use-case: VPUDEC-GPU-eLCDIF
Jignesh Patel
1,912 次查看
Bio_TICFSL
We don´t have any example with LCDIF.
1,912 次查看
jignesh1
Okay but do we have any example of gpu that convert yuv to rgb. So we will try to implement above use case by our self.
Jignesh patel
Get Outlook for Android<https://aka.ms/ghei36>
1,912 次查看
jignesh1
Hello Bio_TICFSL,
We got VPU base decoding example from buildroot. We have tested and it works well. We also manage to play RGB raw file to eLCDIF as per our requirement. So now if we get any reference code for video croma conversion and scaling by GPU that will help us lot.
Please let me know if we have any limitation to implement this pipeline.
Jignesh Patel
