imx8mq Android 10 display scaling issue
3,678件の閲覧回数
gennady_kuznetsov
Greetings,
We have the LVDS display AUO G121XN01 with resolution 1024x768 connected through SN65DSI83 (MIPI-DSI-LVDS bridge) to imx8mq custom board.
On Android 10 (2.6.0) the display is stretched (see photo).
On Android 11 (1.0.0) everything is fine.
Both Androids use the same Linux kernel.
With 1280x800 display both Androids work fine.
Our conclusion so far is that Android 10 display/graphic HAL (supplied by NXP) has an issue with correct display scaling (for low resolutions e.g. 1024x768).
Could you please help us to resolve the issue?
Gennady
6 返答(返信)
3,590件の閲覧回数
gennady_kuznetsov
Please advise if we can somehow fix or workaround this issue. We have a very disappointed customer waiting for the solution.
Best regards, Gennady
3,579件の閲覧回数
Hi Gennady
in such case issue should be reproducable without SN65DSI83, just with i.MX8MQ EVK.
Please provide steps how it can be reproduced  on NXP side with EVK.
Unfortunately SN65DSI83 is not "officially" supported by NXP in its BSPs, for that reason may be
suggested to proceed with help of  https://contact.nxp.com/new-prof-svcs-sw-tech
3,646件の閲覧回数
Hi Gennady
those nxp original android releases have different kernels and gpu drivers as described on below lin
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applications...
so may be recommended to rebuild image from scratch using nxp sources.
3,636件の閲覧回数
gennady_kuznetsov
Hi Igor,
thank you for your reply!
We already use the latest Android 10.0.0_2.6.0, apparently the problem is addressed in Android 11 only.
Gennady
3,631件の閲覧回数
please try NXP Android 10 (2.6.0) with latest L5.4.70_2.3.0 release.
3,628件の閲覧回数
gennady_kuznetsov
We already use 5.4.70 kernel. Sorry if it wasn't clear, it's the only kernel I see available with 10.0.0_2.6.0.
