imx8mp stop m4 when app runs
1,121件の閲覧回数
xjy198903
How can I reliably stop the program running on the M4 core while executing user applications on the A53 core of the imx8mp? I need to perform some specific tests without modifying the device tree or other settings, as the M4 core automatically restarts after a reboot. This way, the M4 core can continue to operate normally when I’m not conducting tests.
1,027件の閲覧回数
danielchen
For M core, you can try
echo stop > /sys/devices/platform/imx8mp-cm7/remoteproc/remoteproc0/state
3 返答(返信)
1,096件の閲覧回数
danielchen
Hi Xjy:
You  can try to use below commands.
For example,  disable CPU1
echo 0 > /sys/devices/system/cpu/cpu1/online
below command to enable CPU 1
echo 1 > /sys/devices/system/cpu/cpu1/online
1,092件の閲覧回数
xjy198903
I just want to stop cortex-m4 not an A53 core of imx8mp,when running services on imx8mp
1,028件の閲覧回数
danielchen
