imx8mp pcie eye pattern test fail
1,701 次查看
jiangyaqiang
Contributor V
Hi :
My board PCIE eye pattern test fail at something, as bellow:
The "low Limit" is a litter too fast.
which register should I tune to pass it ?
I have attachment the complete test report.
标记 (1)
1,690 次查看
igorpadykov
Hi Yaqiang
reason may incorrect testing measurements, may be recommended to recheck them using AN12444
PCIe Certification Guide for i.MX8 Serials
1,685 次查看
jiangyaqiang
Contributor V
Hi igor:
Thanks.
I have checked the file , there is one parameter using in the file: pcie_cz_enabled=yes,
I can't find it in kernel, could you tell me what's the parameter used for ?
BTW, We have test the EVK board, it passed, any we use the same kernel and config in my board, it fail, the fail is a very little margin, so I want to know what register is relative to the fail ?
