Hi @Chavira,
I can say my problems were solved already.
The SDK completely successful created.
Based on my previous reply related to the error
Error:
Problem: package packagegroup-qt6-modules-1.0-r0.imx8mn_lpddr4_evk requires packagegroup-qt6-addons, but none of the providers can be installed
- conflicting requests
- nothing provides qtimageformats needed by packagegroup-qt6-addons-1.0-r0.imx8mn_lpddr4_evk
(try to add '--skip-broken' to skip uninstallable packages)
My first thought that the problems is related to the qtimageformats component, but its actually this qtimageformats is not needed. Just for workaround I just deleted all the files that generated related to the qtimageformats in below folder
/tmp/pkgdata/imx8mn-lpddr4-evk/
/tmp/pkgdata/imx8mn-lpddr4-evk/extended/
/tmp/pkgdata/imx8mn-lpddr4-evk/runtime/
then rerun again and successfully passed and generated the files in sdk folder.
Thanks for your response previously.
I can close this thread as resolved.
Best Regard.
Eddy Wijaya
