imx8mm android platform is not support wm8524 audio codec?
1,007 次查看
13660284951
Hello、
our soc is imx8mm
and platform is android9
First:I found,while dts was enable wm8524 and the device node was created.
Second:use cmd "tinyplay xxx.wav",there was return Unable to open PCM device 0 (cannot set hw params: Invalid argument)  to us。
that absoutly the codec is not supported tinyplay
as we all know,android is use tinyplay componmentes,what can i do?
956 次查看
joanxie
pls refer to the topic as below:
https://community.nxp.com/message/1088007
