hi,
i.MX 8M Mini Migration Guide said imx8m mini sai support 768 kHz audio?which kernel versions support.thanks.
Hi @sofia_0571
建议使用lf-6.1.55-2.2.2,相关的提交是:ASoc: fsl_sai: Add pinctrl operation for PDM and DSD · nxp-imx/linux-imx@b4ee8a9 · GitHub,另外可以参考的回复:https://community.nxp.com/t5/i-MX-Processors/i-MX8M-Mini-SAI1-TX-support-for-768kHz-32-bit-if-only-u...
受限于BCLK,最高只能支持 768Khz, 32bits ,2 channel。Best Regards,Zhiming
now use 4.14.78 version,sai2 only up to 192khz!how to fixup for support 768khz or more than 192khz+.
