I tried to build the image for Myir JX8MMA7 based on imx8m Mini quad, following the users guide i.MX Yocto Project User's Guide (nxp.com.cn) revision 6.6.3.
But there is something wrong with checksum.
Solved! Go to Solution.
this fetch error is related to the network, pls check your network or firewall and try again, sometimes you need try to download more times
