imx8 nano USB Serial Download support
1,669 次查看
agbro
Hello
Does IMX8 Nano processors support USB Serial Download mode?
If yes, what pins should be connected to keep USB connection stable?
2 回复数
1,627 次查看
agbro
I assume it was designed to bootload from external emmc card, otherwise SD card are not readable by processor.
According to schematic of EVK,
1. Connecting USB1_VBUS, USB1_D_N, USB1_D_P, USB1_TXRTUNE are enough to use NXP IMX8 Nano processor in USB Serial Download mode, correct?
2.There is no need to use USB1_ID pin (it is connected to TouchPoint on external PCB),correct?
1,645 次查看
AldoG
You may refer to our EVK as reference for this:
https://www.nxp.com/webapp/Download?colCode=8MNANOLPD4-EVK-DESIGNFILES
Aldo.
