imx8 m mini I'm wondering how to insert an image in the initial state.
1,348 次查看
twkang
hi
Currently I am using imx8 m mini ddr4 evk board
I am in the process of inserting an Android image.
But I don't understand how to put an image using uuu.exe file and mfgtools-uuu_1.3.136, android-10.0.0_1.0.0_image_8mmevkddr4. Please detail the documentation or method for this.
1,308 次查看
diegoadrian
I apologize for the delay.
To download an image using the UUU tool is simple, you just need to set your board into serial download mode and then run the following command at the windows shell terminal.
.\uuu_imx_android_flash.bat -f imx8mm -a -e
Remember that you need to have the uuu.exe file in the same path that you have all your images. Furthermore, that command will only download the image into an sdcard of 16 GB. If you want to use the eMMC memory of the board, you need to change the settings of the script. For more information regarding this, I suggest you follow the Android's_Quick_Start_Guide. There you could find in a more complete way how to use UUU tool.
Diego.
