imx8 bitbake extensible SDK error
8,256件の閲覧回数
Ichi_
Hi all
I have a need for extensible SDK.
I can build SDK by command
bitbake imx-image-full -c populate_sdk,
but can't build extensible SDK by command
bitbake imx-image-full -c populate_sdk_ext.
I'vd tried cleanall imx-image-full and changong python version 2 and 3.
but neither works?
Could anyone please give me advice?Thank you.
The error message is as follows:
oading cache: 100% |############################################| Time: 0:00:00
Loaded 4640 entries from dependency cache.
Parsing recipes: 100% |##########################################| Time: 0:00:00
Parsing of 3218 .bb files complete (3217 cached, 1 parsed). 4641 targets, 464 skipped, 1 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.44.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-20.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mqevk"
DISTRO = "fsl-imx-wayland"
DISTRO_VERSION = "5.4-zeus"
TUNE_FEATURES = "aarch64 cortexa53 crc crypto"
TARGET_FPU = ""
meta
meta-poky = "HEAD:d88d62c20d7d8da85f02edb170dae0280624ad7e"
meta-oe
meta-multimedia
meta-python = "HEAD:2b5dd1eb81cd08bc065bc76125f2856e9383e98b"
meta-freescale = "HEAD:14f1a630a47375432f93c556927b879b51d84c4e"
meta-freescale-3rdparty = "HEAD:dbcc686f52c3c84db8cb86aa8973a4e373651b98"
meta-freescale-distro = "HEAD:ca27d12e4964d1336e662bcc60184bbff526c857"
meta-bsp
meta-sdk
meta-ml = "HEAD:7f0abf664d65ab9f03f85a1d16ab54e0d1134a9b"
meta-nxp-demo-experience = "HEAD:03904c493469907a2829cf29df7ab060f9c664a6"
meta-browser = "HEAD:ee3be3b5986a4aa0e73df2204a625ae1fe5df37e"
meta-rust = "HEAD:53bfa324891966a2daf5d36dc13d4a43725aebed"
meta-clang = "HEAD:711e593d5984aad3bf35c51b7ac4482982bc16c7"
meta-gnome
meta-networking
meta-filesystems = "HEAD:2b5dd1eb81cd08bc065bc76125f2856e9383e98b"
meta-qt5 = "HEAD:21ce4c124d9a972d9122f87c64ac2773bf04c284"
meta-python2 = "HEAD:4400f9155ec193d028208cf0c66aeed2ba2b00ab"
WARNING: /home/sysgration/imx8_5_4/imx8-yocto-bsp/sources/meta-imx/meta-bsp/recipes-kernel/linux/linux-imx_5.4.bb:do_compile is tainted from a forced run
WARNING: /home/sysgration/imx8_5_4/imx8-yocto-bsp/sources/meta-imx/meta-bsp/recipes-kernel/linux/linux-imx_5.4.bb:do_deploy is tainted from a forced run
WARNING: /home/sysgration/imx8_5_4/imx8-yocto-bsp/sources/meta-imx/meta-bsp/recipes-bsp/u-boot/u-boot-imx_2020.04.bb:do_compile is tainted from a forced run
WARNING: /home/sysgration/imx8_5_4/imx8-yocto-bsp/sources/meta-imx/meta-bsp/recipes-bsp/u-boot/u-boot-imx_2020.04.bb:do_deploy is tainted from a forced run
Initialising tasks: 100% |#######################################| Time: 0:00:02
Sstate summary: Wanted 0 Found 0 Missed 0 Current 4036 (0% match, 100% complete)
NOTE: Executing Tasks
NOTE: Setscene tasks completed
ERROR: imx-image-full-1.0-r0 do_sdk_depends: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:extend_recipe_sysroot(d)
0003:
File: '/home/sysgration/imx8_5_4/imx8-yocto-bsp/sources/poky/meta/classes/staging.bbclass', lineno: 551, function: extend_recipe_sysroot
0547: dest = newmanifest[l]
0548: if l.endswith("/"):
0549: staging_copydir(l, targetdir, dest, seendirs)
0550: continue
*** 0551: staging_copyfile(l, targetdir, dest, postinsts, seendirs)
0552:
0553: bb.note("Installed into sysroot: %s" % str(msg_adding))
0554: bb.note("Skipping as already exists in sysroot: %s" % str(msg_exists))
0555:
File: '/home/sysgration/imx8_5_4/imx8-yocto-bsp/sources/poky/meta/classes/staging.bbclass', lineno: 144, function: staging_copyfile
0140: if os.path.islink(c):
0141: linkto = os.readlink(c)
0142: if os.path.lexists(dest):
0143: if not os.path.islink(dest):
*** 0144: raise OSError(errno.EEXIST, "Link %s already exists as a file" % dest, dest)
0145: if os.readlink(dest) == linkto:
0146: return dest
0147: raise OSError(errno.EEXIST, "Link %s already exists to a different location? (%s vs %s)" % (dest, os.readlink(dest), linkto), dest)
0148: os.symlink(linkto, dest)
Exception: FileExistsError: [Errno 17] Link /home/sysgration/imx8_5_4/imx8-yocto-bsp/build-wayland/tmp/work/imx8mqevk-poky-linux/imx-image-full/1.0-r0/recipe-sysroot/lib already exists as a file: '/home/sysgration/imx8_5_4/imx8-yocto-bsp/build-wayland/tmp/work/imx8mqevk-poky-linux/imx-image-full/1.0-r0/recipe-sysroot/lib'
ERROR: Logfile of failure stored in: /home/sysgration/imx8_5_4/imx8-yocto-bsp/build-wayland/tmp/work/imx8mqevk-poky-linux/imx-image-full/1.0-r0/temp/log.do_sdk_depends.835827
ERROR: Task (/home/sysgration/imx8_5_4/imx8-yocto-bsp/sources/meta-imx/meta-sdk/dynamic-layers/qt5-layer/recipes-fsl/images/imx-image-full.bb:do_sdk_depends) failed with exit code '1'
NOTE: Tasks Summary: Attempted 10496 tasks of which 10495 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 5 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
8,125件の閲覧回数
Harvey021
5 返答(返信)
8,224件の閲覧回数
Harvey021
esdk will include debug, which makes it larger. This makes it uncertain whether our wic format is sufficient. If debugging is needed, it is recommended to target a specific package instead of the entire toolchain.
Harvey
8,185件の閲覧回数
Ichi_
Hi @Harvey021
I can build the multimedia version esdk (bitbake imx-image-multimedia -c populate_sdk_ext).
Do you know how to add QT on multimedia esdk?Thanks.
8,170件の閲覧回数
Harvey021
What about the multimedia image burn and flash into board?
As full image includes QT, sorry. I haven't got that experience for adding QT to multimedia.
Harvey
8,165件の閲覧回数
Ichi_
Hi @Harvey021
Because there is a problem by use imx-image-full -c populate_sdk_ext ,
so I need add QT5 then use imx-image-multimedia -c populate_sdk_ext.
Thanks for your reply.
8,126件の閲覧回数
Harvey021
%3CLINGO-SUB%20id%3D%22lingo-sub-1975796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8%20bitbake%20extensible%20SDK%20%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1975796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E6%8B%A1%E5%BC%B5%E5%8F%AF%E8%83%BD%E3%81%AASDK%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7SDK%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%3C%2FP%3E%3CP%3Ebitbake%20imx-image-full%20-c%20populate_sdk%E3%80%81%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%8B%A1%E5%BC%B5%E5%8F%AF%E8%83%BD%E3%81%AASDK%3C%2FSTRONG%3E%20%E3%82%92%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ebitbake%20imx-image-full%20-c%20populate_sdk_ext.%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFcleanall%20imx-image-full%E3%81%A8changong%20python%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32%E3%81%A83%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EOAD%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A00%3CBR%20%2F%3ELoaded%204640%20entries%20from%20dependency%20cache.%3CBR%20%2F%3EParsing%20recipes%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%E6%99%82%E9%96%93%3A%200%3A00%3A00%3CBR%20%2F%3E3218%20.bb%E3%81%AE%E8%A7%A3%E6%9E%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(3217%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%811%20%E8%A7%A3%E6%9E%90)%E3%80%824641%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%80%81464%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%80%811%20%E3%83%9E%E3%82%B9%E3%82%AF%E3%80%810%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AE%E8%A7%A3%E6%B1%BA%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3EBB_VERSION%20%3D%20%221.44.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%20%3D%20%22ubuntu-20.04%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%20%3D%20%22imx8mqevk%22%3CBR%20%2F%3EDISTRO%20%3D%20%22fsl-imx-wayland%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%225.4-%E3%82%BC%E3%82%A6%E3%82%B9%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22aarch64%20cortexa53%20crc%20crypto%22%3CBR%20%2F%3ETARGET_FPU%20%3D%20%22%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%3CBR%20%2F%3Emeta-poky%20%3D%20%22%E3%83%98%E3%83%83%E3%83%89%3Ad88d62c20d7d8da85f02edb170dae0280624ad7e%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BFOE%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3CBR%20%2F%3E%E3%83%A1%E3%82%BFpython%20%3D%20%22HEAD%3A2b5dd1eb81cd08bc065bc76125f2856e9383e98b%22%3CBR%20%2F%3Emeta-freescale%20%3D%20%22%E3%83%98%E3%83%83%E3%83%89%3A14f1a630a47375432f93c556927b879b51d84c4e%22%3CBR%20%2F%3Emeta-freescale-3rdparty%20%3D%20%22HEAD%3Adbcc686f52c3c84db8cb86aa8973a4e373651b98%22%3CBR%20%2F%3Emeta-freescale-distro%20%3D%20%22HEAD%3Aca27d12e4964d1336e662bcc60184bbff526c857%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BFBSP%3CBR%20%2F%3E%E3%83%A1%E3%82%BFSDK%3CBR%20%2F%3Emeta-ml%20%3D%20%22%E3%83%98%E3%83%83%E3%83%89%3A7f0abf664d65ab9f03f85a1d16ab54e0d1134a9b%22%3CBR%20%2F%3Emeta-nxp-demo-experience%20%3D%20%22HEAD%3A03904c493469907a2829cf29df7ab060f9c664a6%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%96%E3%83%A9%E3%82%A6%E3%82%B6%20%3D%20%22HEAD%3Aee3be3b5986a4aa0e73df2204a625ae1fe5df37e%22%3CBR%20%2F%3Emeta-rust%20%3D%20%22%E3%83%98%E3%83%83%E3%83%89%3A53bfa324891966a2daf5d36dc13d4a43725aebed%22%3CBR%20%2F%3Emeta-clang%20%3D%20%22%E3%83%98%E3%83%83%E3%83%89%3A711e593d5984aad3bf35c51b7ac4482982bc16c7%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%8E%E3%83%BC%E3%83%A0%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%3CBR%20%2F%3Emeta-filesystems%20%3D%20%22HEAD%3A2b5dd1eb81cd08bc065bc76125f2856e9383e98b%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%20qt5%20%3D%20%22%E3%83%98%E3%83%83%E3%83%89%3A21ce4c124d9a972d9122f87c64ac2773bf04c284%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BFpython2%20%3D%20%22%E3%83%98%E3%83%83%E3%83%89%3A4400f9155ec193d028208cf0c66aeed2ba2b00ab%22%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3A%20%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fsources%2Fmeta-imx%2Fmeta-bsp%2Frecipes-kernel%2Flinux%2Flinux-imx_5.4.bb%3Ado_compile%20%E3%81%AF%E5%BC%B7%E5%88%B6%E5%AE%9F%E8%A1%8C%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fsources%2Fmeta-imx%2Fmeta-bsp%2Frecipes-kernel%2Flinux%2Flinux-imx_5.4.bb%3Ado_deploy%20%E3%81%AF%E5%BC%B7%E5%88%B6%E5%AE%9F%E8%A1%8C%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fsources%2Fmeta-imx%2Fmeta-bsp%2Frecipes-bsp%2Fu-boot%2Fu-boot-imx_2020.04.bb%3Ado_compile%E5%BC%B7%E5%88%B6%E5%AE%9F%E8%A1%8C%E3%81%AB%E3%82%88%E3%82%8A%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fsources%2Fmeta-imx%2Fmeta-bsp%2Frecipes-bsp%2Fu-boot%2Fu-boot-imx_2020.04.bb%3Ado_deploy%E5%BC%B7%E5%88%B6%E5%AE%9F%E8%A1%8C%E3%81%AB%E3%82%88%E3%82%8A%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%E6%99%82%E9%96%93%3A%200%3A00%3A02%3CBR%20%2F%3E%E7%8A%B6%E6%85%8B%E3%81%AE%E6%A6%82%E8%A6%81%3A%20%E5%8B%9F%E9%9B%86%200%20%E7%99%BA%E8%A6%8B%200%20%E8%A6%8B%E9%80%83%E3%81%97%200%20%E7%8F%BE%E5%9C%A8%204036%20(%E4%B8%80%E8%87%B4%E7%8E%87%200%E3%80%81%E5%AE%8C%E4%BA%86%E7%8E%87%20100%25)%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E6%B3%A8%3A%E3%82%BB%E3%83%83%E3%83%88%E3%82%B7%E3%83%BC%E3%83%B3%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20imx-image-full-1.0-r0do_sdk_depends%3A%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9Fexec_python_func()%E3%81%A7Python%E9%96%A2%E6%95%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E4%BE%8B%E5%A4%96%2F%E5%A4%B1%E6%95%97%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%9FPython%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20'exec_python_func()%20%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90'%2C%20lineno%3A%202%2C%20%E9%96%A2%E6%95%B0%3A%20%3CMODULE%3E%3CBR%20%2F%3E0001%3A%3CBR%20%2F%3E0002%3Aextend_recipe_sysroot(d)%3CBR%20%2F%3E0003%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20'%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Fclasses%2Fstaging.bbclass'%2C%20lineno%3A%20551%2C%20%E9%96%A2%E6%95%B0%3A%20extend_recipe_sysroot%3CBR%20%2F%3E0547%3A%20dest%20%3D%20newmanifest%5Bl%5D%3CBR%20%2F%3E0548%3A%20L.EndsWith(%22%2F%22)%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E0549%3A%20staging_copydir(l%2C%20targetdir%2C%20dest%2C%20seendirs)%3CBR%20%2F%3E0550%3A%20%E7%B6%9A%E8%A1%8C%3CBR%20%2F%3E0551%3A%20staging_copyfile(l%2C%20targetdir%2C%20dest%2C%20postinsts%2C%20seendirs)%3CBR%20%2F%3E0552%3A%3CBR%20%2F%3E0553%3A%20bb.note(%22sysroot%20%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20%25s%22%20%25%20str(msg_adding))%3CBR%20%2F%3E0554%3A%20bb.note(%22sysroot%20%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3A%20%25s%22%20%25%20str(msg_exists))%3CBR%20%2F%3E0555%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20'%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Fclasses%2Fstaging.bbclass'%2C%20lineno%3A%20144%2C%20function%3A%20staging_copyfile%3CBR%20%2F%3E0140%3A%20os.path.islink(c)%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E0141%3A%20linkto%20%3D%20os.readlink(c)%3CBR%20%2F%3E0142%3A%20os.path.lexists(dest)%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E0143%3A%20os.path.islink(dest)%20%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E0144%3A%20OSError(errno.EEXIST%2C%20%22%E3%83%AA%E3%83%B3%E3%82%AF%20%25s%20%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%22%20%25%20dest%2C%20dest)%3CBR%20%2F%3E0145%3A%20os.readlink(dest)%20%3D%3D%20linkto%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E0146%3A%20%E5%B8%B0%E9%82%84%E5%9C%B0%3CBR%20%2F%3E0147%3A%20OSError(errno.EEXIST%2C%20%22%E3%83%AA%E3%83%B3%E3%82%AF%20%25s%20%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%88%A5%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F(%25s%20vs%20%25s)%22%20%25%20(dest%2C%20os.readlink(dest)%2C%20linkto)%2C%20dest)%3CBR%20%2F%3E0148%3A%20os.symlink(linkto%2C%20dest)%3CBR%20%2F%3E%E4%BE%8B%E5%A4%96%3AFileExistsError%3A%5B%E3%82%A8%E3%83%A9%E3%83%BC%E7%95%AA%E5%8F%B717%5D%E3%83%AA%E3%83%B3%E3%82%AF%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fbuild-wayland%2Ftmp%2Fwork%2Fimx8mqevk-poky-linux%2Fimx-image-full%2F1.0-r0%2Frecipe-sysroot%2Flib%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%3A'%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fbuild-wayland%2Ftmp%2Fwork%2Fimx8mqevk-poky-linux%2Fimx-image-full%2F1.0-r0%2Frecipe-sysroot%2Flib'%3C%2FMODULE%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fbuild-wayland%2Ftmp%2Fwork%2Fimx8mqevk-poky-linux%2Fimx-image-full%2F1.0-r0%2Ftemp%2Flog.do_sdk_depends.835827%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF%EF%BC%88%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fsources%2Fmeta-imx%2Fmeta-sdk%2Fdynamic-layers%2Fqt5-layer%2Frecipes-fsl%2Fimages%2Fimx-image-full.bb%EF%BC%89do_sdk_depends)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%2010496%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%2010495%20%E5%80%8B%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%3A%201%20%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%2Fhome%2Fsysgration%2Fimx8_5_4%2Fimx8-yocto-bsp%2Fsources%2Fmeta-imx%2Fmeta-sdk%2Fdynamic-layers%2Fqt5-layer%2Frecipes-fsl%2Fimages%2Fimx-image-full.bb%3Ado_sdk_depends%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%3A5%E3%81%A4%E3%81%AE%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%3A%201%20%E3%81%A4%E3%81%AE%20ERROR%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%810%20%E4%BB%A5%E5%A4%96%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
