imx7d: Changing PLL_DDR DIV_SELECT (CCM_ANALOG_PLL_DDRn)
EvenFlow
Can DIV_SELECT be changed in CCM_ANALOG_PLL_DDRn directly?
For CCM_ANALOG_PLL_DDR_NUM and CCM_ANALOG_PLL_DDR_DENOM the manual says that POWERDOWN bit needs to be written, but I see no such limitation for CCM_ANALOG_PLL_DDRn.
JorgeCas
There is no such limitation to write in CCM_ANALOG_PLL_DDRn register.
Best regards.
