- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
1. Does successful entry into Serial Download Mode guarantee the following hardware is functional?
Yes, if the board is entering to serial download mode, you are following the power-up sequence.
2. Is the ALU used by BootROM the same as the one used by U-Boot?
What are you referring with ALU?
3. Should Boot Mode pin configuration be verified even after entering Serial Download Mode?
Not, once is in serial download mode, the changes in boot mode pins does not affect the boot source.
4. Does the SRAM program require specific initialization code (e.g., disabling the watchdog)?
We do not have documentation to initialize the processor and run an standalone application but DDR tool stress test.
5. Are there other critical hardware modules to inspect (e.g., clock source, reset circuit)?
I suggest you run the DDR tool stress test that will let you know if your board has hardware issues in DDR layout.
6. Which signals should be measured with an oscilloscope?
Clock signals and boot mode pins voltage levels just to confirm.
Best regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Best regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Before this.
I am speculating whether IMX6 has a hidden core, with built-in ALU and a series of arithmetic units, specifically for the boot stage.
So my speculation is not possible.
