imx6ull eval board flexCAN connector
2,002 次查看
dluberger
Contributor V
The BOM for the imx6ull eval board specifies J1201 as Shenzen p/n WF1250801200 but I can't find this part on digikey or even octopart, so I can't identify a mating connector, let alone buy one. I want to create a loopback attachment to connect CAN0 to CAN1 so that I can do some CAN testing prior to developing external hardware for CAN-connected sensors.  Please help identify a compatible mating connector or cable that will fit in this connector.  Thanks.
标签 (2)
1,877 次查看
Bio_TICFSL
Hi David,
You can check the WF1250801200 on:
http://www.globalsources.com/asia-atom.co
regards
1,878 次查看
Bio_TICFSL
Hi David,
regards
