imx6ull driver SGTL5000 problem
1,671 次查看
michael_yang
imx6ull driver SGTL5000 but MCLK not output,  if we provide the SGTL5000 with an external MCLK, MCLK can output clock, pls help to check this issue.
1,643 次查看
Sanket_Parekh
Hi @michael_yang
Are you still facing the same issue?
If No, Then can i mark this ticket to close state?
Thanks & Regards.
Sanket Parekh
1,654 次查看
Sanket_Parekh
Hi @michael_yang
I hope you are doing well.
To debug this issue i need board DTS file, imx6ul.dtsi, and imx6ull.dtsi files.
If possible, Could you please share the above mentioned files?
Thanks & Regards.
Sanket Parekh
