imx6ulevk
imx6ulevk
2,292 次查看
xinjianlu
hi,在imx6ulevk里,用74LV595PW去控制复位功能。
驱动在drivers/gpio/gpio-74x164.c
有个问题是比如CSI_RST,CSI_PWDN,LCD_nPWREN 的控制实现相应的驱动在文件里?
2,118 次查看
jimmychan
I think CSI_RST is the reset for the camera.
you can setup the GPIO pin for CSI_RST in your board's dtsi file.
you can use it in the drivers by of_get_named_gpio().
for example : ov5640.c, you can find the of_get_named_gpio() to get the pwn_gpio in ov5640_probe().
2,118 次查看
xinjianlu
但LCD_nPWREN 这一pin实际没有找到,就是说LCD屏的电源控件使能是什么实现
