imx6ulevk kernel configuration .cfg file not work
1,355件の閲覧回数
lujfsd
I want to add iptables into my images, so i create my support-iptables.cfg file. but is not work.
this is my support-iptables.cfg file:
Run:bitbake fsl-image-machine-test command。when finish ,not found the kernel configuration  in build/.config file.
so,how it is work. sorry for my english。Thanks!
ラベル(2)
1,135件の閲覧回数
gusarambula
Hello Jiefeng Lu,
If you wish to edit your kernel configuration I would recommend looking at the following Community Document which is a simple but very informative training on how to do so.
https://community.nxp.com/docs/DOC-95045
I hope this helps!
