imx6ul gpio
imx6ul gpio
2,649 次查看
ninghongxie
If imx6ul uses gpio_set_value function to simulate a certain time sequence, it will cause CPU occupancy rate to be particularly high. If I operate the GPIO DR register myself, this will not happen.
2,316 次查看
igorpadykov
Hi ninghong
you are right, also one can look at below link for suggestions how to increase speed
https://community.nxp.com/message/841330?commentID=841330#comment-841330
2,316 次查看
ninghongxie
Hi igorpadykov
    Thank you for your advice, but I think this is a different case. Now I am driven by linux, frequently calling the interface gpio_set_value will cause the whole Linux system to become very slow, and even affect other functions.
2,316 次查看
ninghongxie
Can imx6 GPIO set registers that specify a bit change? So I can use registers to control my driver directly. Not considering mutex
