imx6ul Log information
2,103 次查看
jieh朱
Hello there
I use imx6ul kernel version is linux4.14.78. I view the system log
# cat /var/log/syslog
He can only save the information of the last startup. The previous log information cannot be saved.
How can I modify it. He can save more information
I checked /etc/syslog.conf and I didn't see any changes
2,049 次查看
karangajjar
Senior Contributor II
Hi  jiehuai zhu,
You can use journaling as described in below link (you might need to preserve time else logs will be overwritten):
https://www.digitalocean.com/community/tutorials/how-to-use-journalctl-to-view-and-manipulate-system...
Also, if you want to save syslog at reboot you can use:
crontab -e
@reboot sudo cat /var/log/syslog >> /home/root/syslog
Karan Gajjar
