imx6ul Log information
jieh朱
Hello there
I use imx6ul kernel version is linux4.14.78. I view the system log
# cat /var/log/syslog
He can only save the information of the last startup. The previous log information cannot be saved.
How can I modify it. He can save more information
I checked /etc/syslog.conf and I didn't see any changes
karangajjar
Senior Contributor II
Hi  jiehuai zhu,
You can use journaling as described in below link (you might need to preserve time else logs will be overwritten):
https://www.digitalocean.com/community/tutorials/how-to-use-journalctl-to-view-and-manipulate-system...
Also, if you want to save syslog at reboot you can use:
crontab -e
@reboot sudo cat /var/log/syslog >> /home/root/syslog
Karan Gajjar
