imx6q video display problem
3,276件の閲覧回数
lampo
Hello,  I want to preview my video on HDMI LCD,   my cmos sensor is 8 bit grayscale, 752x480.  and I tested it with mxc_v4l2_overlay.c  from imx_test package.
I find the image show in LCD  in not the same as the sensor output,  i.e. smaller , copied to 16 same images,   green background!   (see the attachment)
I want to know if  grayscale image direct preview is supported by imx6q?   if yes, how should I modified the driver(I have modified the driver for capture grayscale sensor image, but not for preview)?
or do I have to first  capture it to mem,then output to LCD (mxc_v4l2_output.c)?
thanks a  lot !
3 返答(返信)
3,086件の閲覧回数
joanxie
I have a sample code for jpeg camera sensor, this is for 8bit grayscale, but Im not sure if I can uploade here, you can create a ticket, then I send to you.
https://community.nxp.com/docs/DOC-329745
3,086件の閲覧回数
lampo
thanks a lot, Joan.  Could you please send to  [email protected] ?    really appreciated!
3,086件の閲覧回数
lampo
Does anyone know how to modify mxc_v4l2_output.c  to display gray image on LCD?   thanks a lot.
