imx6q use DDR_Tester
1,481 次查看
yacheng_zhang
Hi everyone.
     I made a imx6q board and want to calibrate DDR3 with ddr_stress_tester_v2.90.But I  found the target list without MX6Q.So i wonder why?Did I download the correct version of the DDR3 with ddr_stress_teste.Can you send me a correct version and configuration script to support IMX6Q?
      Thank you
1,470 次查看
Rita_Wang
The i.MX6DQ is standing for i.MX6Q and i.MX6D. The one you are using is the right one for the i.MX6Q.
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX6-DDR-Stress-Test-Tool-V1-0-3/ta-p/1...
1,471 次查看
Rita_Wang
