imx6q how to calculate CAN bit rate?
813 次查看
chenbl
Hi all,
    Is there any tools for calculate CAN bit rate and sample point?
for example, frequency 1GHz, i want got 1M bit rate and 85.7% sample point,
How should i set the CTRL1 parameters
BR.
808 次查看
nxf63675
Hi @chenbl,
Please refer to the document below, is for another processor from NXP but can be used as an example of for the i.MX devices.
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/FlexCAN-bit-timing-calculation/ta-p/1122068
Hope this helps you.
Israel.
