imx6q blob encapsulation and decapsulation
1,969 次查看
yilingxu
If I only want to generate a general blob (red blob). Neither secure memory blob, nor black key.  Do I need to read and write caam-sm? In other world, whether I can disable caam-sm node in device tree if I only want to generate a general blob?
caam_sm node in device tree as follow:
caam_sm: caam-sm@00100000 {
   compatible = "fsl,imx6q-caam-sm";
   reg = <0x00100000 0x4000>;
1,833 次查看
yilingxu
Whether "using master key to derive a blob-key encryption key" need caam-sm?
1,833 次查看
Yuri
  I've sent You some comments directly.
Yuri.
1,833 次查看
yilingxu
I have received email, thanks for your contribution.
