imx6q VPU support
imx6q VPU support
3,613 次查看
flobro
we are "stuck" with Linux 4.9.175 kernel with iMX6q and are looking for a solution for VPU video decoding. I see that there is a VPU driver in the kernel,  but I assume that more support is needed for doing a simple decode.
Questions: Do I need CONFIG_MXC_GPU_VIV with CONFIG_MXC_VPU?
I cannot seem to get the CONFIG_MXC_GPU_VIV to stick in menuconfig (I save it, then go back in and it is disabled...)
Thanks in advance.
标记 (3)
3,600 次查看
Zhiming_Liu
If you are using mainline kernel version, you may need porting VPU driver from kernel we release.
https://github.com/nxp-imx/linux-imx/tree/rel_imx_4.9.88_2.0.0_ga/drivers/mxc
4 回复数
3,596 次查看
flobro
Thank you for the reply. I will try that.
The current code I have seems to lock up the kernel as soon as the module loads.
3,601 次查看
Zhiming_Liu
3,566 次查看
flobro
I managed to get the imxvpudec driver(s) working with gstreamer to decode video files to jpeg/png frames. The only issue is there seems to be no support for "videorate' (maybe due to no timestamps in the video) - so the issue is speed.
3,589 次查看
flobro
Anyone know of a simple VPU decoder test? (does it use vpuwrap, or some other library)...
