imx6SL ethernet EMI problem
1,539 次查看
fisherhe
   I use imx6sololite and the ethernet topology is as blows:
      Now there is EMI problem on ethernet coming from the clock(FEC_REF_CLK). Then  I set the SRE of this pad to slow, but it has no help.
      Is there any other metholds to decrease the EMI coming out of the ethernet clock.Will setting DSE bit useful?or other metholds suggested?
      Many thanks.
1,513 次查看
Yuri
fisherhe
   The DSE bit field (drive strength) affects EMI environment.
The similar result may be achieved if use series resistor.
Yuri.
