imx6 virtual comm
imx6 virtual comm
3,776 次查看
joshk
Newbie in this realm and as the question states I'm having difficulty getting my USB port to become a serial port.
I'm using the fsl_imx6_sabrelite BSP and I wanted to know if there are any examples out there that I might be able to follow.  I've USB 3.0 document until I can not longer see straight but no matter what I do I cannot seem to get the port to initialize and have my Windows PC detect the COMM port.  Any help would be appreciated.
标签 (2)
3,658 次查看
EricNelson
Senior Contributor II
Hi Josh,
What you're looking for is a module named "g_serial". Depending on what kernel build you have, we may or may not have included it.
4 回复数
3,658 次查看
SergioSolis
are you using the sabre lite from boundary devices?
3,659 次查看
EricNelson
Hi Josh,
3,658 次查看
joshk
Figured it out after some hefty digging.  Thanks for the help.
3,658 次查看
joshk
Which Kernel would have this?
