imx6 playing high bitrate stream issue
947件の閲覧回数
jake
Dear All,
how to play high bitrate rtsp stream  smoothly in imx6 ?
It can played very well at the bitrate around 3~5Mbps,
but  I  try to played  8~20 Mpbs stream, the screen become broken textures  and  lag.
play on stream:  19Mbps, mxplayer
play on local: the same video and player
I use the VLC player v2.2.1 for  streaming server,
and client is MXplayer using hw+ decode, base on imx.6dl ,android 4.3.1.
the test video website is 2D Demo Trailers (HD)
and can be download it at 2D Demo Trailers (HD) Download Center
Could you give some advices to improve the playback quality , thx a lot !
791件の閲覧回数
joanxie
what bitrate when you play on the second scenario? the same 19Mbps? it seems the bitrate is too high, maybe you can try to use the debloking filter, and the quailty of video from rtsp depends on the network quality, not only the vpu performance.
